ROW1 inclusive extra
wenklaw
Recently noticed the addition of ROW1 as an inclusive extra on my all rounder plan, my question, if i select this as an inclusive extra do i also need to increase my spend cap which is currently set to £0?  I dont see why i would but you never know!
I like to avoid dialling chargeable numbers thats why my spend cap is zero, dont really want to change it.
Rach_H
Hi @wenklaw,
Welcome to the Community!
If you select an inclusive extra then you won't need to change your Spend Cap for this.
Where is it you're travelling to?
Rach
Rach_H
Hi @wenklaw,
Rach
