ROAMING PASS USA not working
richardcolson
Hi I've arrived in the USA Boston area and my iphone isn't working on Data Roaming
I paid for a Roaming Pass for a month before I left the UK
I've tried many of the solutions like selecting network etc
I just can't get it to provide me with data
ANy help would be appreciated
I can't call EE from my phone for some reason. I tried using the international 150 number
@richardcolson : Can you make calls & texts?
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
richardcolson
This is now solved
Thanks for your replies and to EE
Richard
Peter_W
Hey there @richardcolson, I'm really glad to hear you managed to get this all sorted out.
Thanks for taking the time to come by and let us know, and I hope you enjoy the rest of your time in the US too.
Peter
