on
02-11-2024
10:24 PM
- last edited on
02-11-2024
10:45 PM
MikeT
Hi I am having the same issue. Seem to have started when I returned from France.
I have had the network refreshed in store and reset it on the phone.
Roaming has been turned off. All the general data test have been done by the technical team. I have done what you said above and nothing seems to resolve this.
on 03-11-2024 08:14 AM
Yes they work fine on wifi
on 03-11-2024 01:47 PM
@chunkybetty
What make/model device are you using?
Have you been able to complete a network settings reset?
Ali
on 03-11-2024 01:54 PM
It's a samsung s22 and yeah all that's been done
on 03-11-2024 02:28 PM
@chunkybetty
What's the error message you see when trying to use those Apps on mobile data?
Ali
on 03-11-2024 02:39 PM
Something went wrong please reload page
on 03-11-2024 03:03 PM
@chunkybetty
Can you go to settings > connections > Mobile networks > Access Point Names > "Internet" should have a blue highlight by it.
Click the 3 dots at the top right > press "Reset to Default"
Then try the apps again?
Ali
on 03-11-2024 03:08 PM
Hi it doesn't have a reset By default just discard
on 03-11-2024 03:19 PM
@chunkybetty
Thanks for the screenshot.
On that screen press back to get to "access point names", then click the 3 dots to the top right.
Ali
on 03-11-2024 03:30 PM
That seems to have worked .. thankyou so much
on 03-11-2024 03:43 PM
@chunkybetty
You're welcome! Glad I was able to help you with this and your Social Media services are working again.
Ali
