On holiday Lanzarote
Jodie22030323
Hi currently in Lanzarote. My plan says I have roaming within my service plan but I’m unable to make any calls . I’ve increased my spending cap. Turned roaming on and off . Tried to call EE but they cut me off and send a text when I reply to the text it doesn’t go through and says I’m trying to do something that will take me over my spend cap. I can’t figure it out or speak to an agent . Any help please ?
@Jodie22030323 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Ritu_D
Hi @Jodie22030323
Thanks for reaching out to us here in the community.
I am gutted to hear you are unable to use your phone whilst in Lanzarote and i would love to help you get this resolved.
Did you activate roaming on your account before you left by texting ROAMING to 150? Having a roaming add on doesn't always activate roaming too.
Most the time a quick reboot of the phone can also resolve this issue, would you be able to give that a go?
It's great you have increased your spend cap too.
If you have access to your online account you could login and go to MENU > ACCOUNT SETTINGS > PARENTAL AND DATA CONTROLS > ROAMING ABROAD and also CALL ABROAD and PREMIUM RATE. They will show as ticked if roaming and calling abroad is activated. If they are not ticked try selecting them to see if you can activate them.
Ritu
Schockwave
@Ritu_D , on the app, for roaming abroad, it just says you have to ring customer service to get this activated on 150, there is no tick and I do have roaming activated on my account, the other two you can see ticked.
Does this still exist? I thought it went ages ago.
Ritu_D
Hi @Jodie22030323
Sorry it does seem the option to tick Roaming is not available anymore well spotted @Schockwave.
Like @XRaySpeX has mentioned above if rebooting the phone doesn't work you would need to call our customer service team.
Thanks and have a great time in Lanzarote.
Ritu
