Not receiving text messages while abroad in Pakistan
Minihussain
I have had a family emergency and had to travel back to Pakistan but unable to receive SMS. My spend cap is on £30 so not sure what the issue is?
I was in Pakistan a few weeks ago and spoke to someone about the same issue.
Alot of apps need verification by sms and this is causing such inconvenience
Northerner
Hi @Minihussain
Have you activated roaming on your account. If not you'll need to speak to EE CS via Skype on WiFi using the number in my signature.
