No service at all in Madrid
Oz14
I’ve been in Madrid for two days now and I don’t seem to have any service at all . What’s the problem
Have you ever had service abroad? If not...
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
