16-07-2024 08:41 AM
Hi Everyone
I’ve been using a Netgear Nighthawk M2 with an unlimited data sim for the past couple of years and it has worked perfectly. A week ago it has decided not to connect to 4g and is constantly ‘searching’ and displays a message “Mobile Broadband Disconnected - your data connection is disconnected”. Initially I thought this was a signal/locality issue as I was away on holiday, but have returned home today and it’s still refusing to connect to EE. I’ve carried out a full factory reset on the Nighthawk M2 but nothing I do works. Is it likely to be an APN issue? Perhaps a firmware update? Any help/advice will be gratefully appreciated as I’m going away again next week and really need to get the router up and running. Thanks, David
13-08-2024 07:26 PM
13-08-2024 09:02 PM
Hi David
Thank you for taking the time to report your findings. In this day and age you come to expect top notch customer service from tech companies, they must be aware of forums like this and the impact that negative opinions will have. But you have shown that Netgear clearly didn't get the memo! I am glad yours was a happy ending, as mine was because ebay have already confirmed that my refund is being processed. They are very good like that whenever you buy something that turns out to be faulty. It's one of the reasons why I prefer buying like that instead of forking out twice as much for a new product, and then often struggle to get a refund. But Amazon also have a good reputation in that regard so well done. I have made a note of the ZTE that you mentioned and that may well be my next purchase.
Mike
21-08-2025 06:09 PM
I had exactly the same problem - I believe it is in the EE network
I spent several hours over a few days talking to Netgear Hogh Level support in California
In the end it transpires that the only UK network that Netgear certified in the UK was Vodafone
Changed to Vodafone and it worked OK
12-10-2025 09:01 PM
Turn off 3g 👍🏻
12-10-2025 09:05 PM
@ColinTynan1 : 3G is off anyway. The 3G network was switched off a year or 2 back.
