My date isn’t in France
Tridon
Hi
@Tridon : Can you make calls & texts?
Tridon
Hi can you lift up my cap because my date isn’t working I’m in France
Minkey1
Star Contributor
Star Contributor
@Tridon
Is it like Sleepless in Seattle?
Have you tried Italy?
Good luck ❤️
Mike
EE Fibre 900 via SH+ with 2 Extenders, EE TV Pro & Mini boxes, 2 EE SIM's only, all originally BT.
LG Oled, Denon/Cambridge Audio 7.1, Panasonic 4K player, Apple TV 4K
