15-05-2025 04:10 PM
hi iam in australia and have a uk sim and i have the correct roaming pass, i got a message when i arrived saying "while you're here thanks to your roaming pass you can use your uk plan allowances" but when i try to call nothing happens no ringing sound, i also have been told someone has tried to call me but i didnt recieve a call. Data works fine just not calls
i tried to switch to telstra and it let me call someone however i cant always access telstra, why doesnt it work on any other service like optus or vodophone for example? thanks
15-05-2025 06:17 PM
@benc81932 Depends on who EE roaming partner is. You’re basically asking why doesn’t my EE sim work on o2 or Voda.
Have you restarted the device since you got there ?
15-05-2025 06:19 PM
Roaming means using foreign network. O2 & VF are both UK networks, the same as EE.
15-05-2025 06:19 PM
15-05-2025 06:33 PM
My hunch would be a VoLTE issue.
