I've paid for an add on but I'm unable to make calls or text
Paulb1976
[Mod edit: add title]
Christopher_G
Hi @Paulb1976
Welcome to the community.
Are you on contract or pay as you go? Does your phone show a good indication of signal at the top of your screen? Have you tried restarting your phone?
