I've arrived In America and have no signal
Andie3691
I've arrived In America and have no signal I need to add a package buy can't contact 150 or the number that comes up csn someone please contact me to sort this out
[Mod edit: add title]
1 ACCEPTED SOLUTION
Post moved to a new thread.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 9566000 using a web-calling app over WiFi.
