03-04-2025 05:44 PM
03-04-2025 05:57 PM
You've put a statement in the subject line of your post, but it's been cut short and you've not put any explanation in the actual message itself. But I'm going to assume you're abroad and your phone isn't working....
03-04-2025 06:58 PM
Thanks Bristolian
This is the full text.
I'm currently in the US and although I'm on an All Rounder plan with Inclusive extra which has been selected as ROW1 for roaming in Zone 1 countries. I'm unable to make or receive calls. I have data and can send and receive text messages, just not calls. I can't even call EE the customer service number or 150. Can you help please? Thanks. Geoff Little
04-04-2025 09:07 AM
Thanks for explaining what is happening.
Have you tried to manually connect to each of the available networks to see if the same happens on all of them?
What happens when you try to make a call?
Michael
