‎08-01-2025 12:59 AM
‎08-01-2025 08:02 AM
You've put a part-sentence in the subject line but no actual question in your message. That said, I'll guess....
‎08-01-2025 12:10 PM
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
