How to deactivate roaming on PAYM
Plymouthbloke1
Skilled Contributor
Skilled Contributor
Hi there,
How can you deactivate roaming at account level on a PAYM plan? You used to be able to do it via the online account but I can’t find the option anymore?
Thanks 😀
The option to toggle roaming ability was removed from myEE several years ago.
There's no real gain from disabling roaming now, unless you're having issues in a border region?
