Help I am abroad and cannot receive messages for 2 step bank verification!
dnsmukasa
On many travels abroad, although not on Roaming, I am able to receive 2 bank verification notices, NHS texts etc.  I find this is not the case this September, and I am not sure what has changed at EE.  Can anybody advise please?  To all EE is extremely expensive from where I am at the moment.
6 REPLIES 6
@dnsmukasa : If you are abroad & receiving texts you are roaming. Where are you now?
Can you make calls & texts?
Thanks for your response.  I did not  am not activate Roaming as I rushed out the country, but have NEVER had this problem abroad.  A welcome text message is sent on first connection, as the plane lands and links to the Ugandan network and also advises of charges.   I am on EE contract for very many years, and this has never happened to me before.  It is bad for business as it stymies two factor authentication now required by financial institutions.  I am told by EE WhatsApp that I need a password that is not the MYEE password, can you believe that?  They said, "unfortunately, now there are no ways to validate the account to get into it and make the changes", so in 2024 I am now locked out until my return to the UK.  This is outrageous!
Ali_A
Hi @dnsmukasa
Are you able to send and receive normal text messages while abroad?
If you can do, it will indicate that your roaming services are active.
Ali
Perhaps you had roaming enabled in EU but not worldwide.
Roaming means using your phone on foreign networks, which in turn creates the ability to send & receive SMS, make & receive calls and use mobile data.
Which country were you in when you were last able to roam? Which country are you in now?
Uganda, Greece, Uganda
