EU Roaming
Thecoach101
I have EU Roaming - sounds silly but does that cover me in Poland?
thanks
@Thecoach101  Yes it does.  Don’t forget to enable roaming on your account before you leave the UK. Text ROAMING to 150.  Do it now as it’s costs nothing to have roaming enabled on your account.  This means you’ll connect to a roaming network.
@Thecoach101 : Yes. You may use your usual UK allowances in the EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2.47 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £25 / billing month.
tamBre77
i am confused on the costs - I have a contract that gives me 20GB if i get charged the 2.47 a day can i make use of that data whilst i am abroad (also going to corfu) - i am only going for 7 days and dont want to pay the £25 if i can get away with the £2.47 a day thanks
Yes, @tamBre77 , you may your data in the EU & you will be charged £2.47 for each day you do so.
