03-04-2025 01:16 PM
I'm travelling to China and planning to activate 7 day roaming to use my plan as normal. Does anyone know if WhatsApp etc. will work this way or will I also need a VPN? Thanks
03-04-2025 01:07 PM
I'm travelling to China and planning to activate the 7 day travel plan to use my package and normal over there. Does anyone know if WhatsApp etc. will work that way or will I still need a VPN too? Thanks
03-04-2025 01:27 PM
@Pinkfrog19 Yes what’s app should work as it uses data. And yes I would personally use a VPN.
A quick google search brings up
While roaming in China, you can technically use a VPN, but be aware that the Chinese government only approves VPNs that comply with its requirements, and bans those that don't
03-04-2025 01:53 PM
EE roaming in China is all tunnelled through the UK. Therefore, in my experience (Feb 2025), you won’t encounter any blocked pages, and won’t need a VPN for this purpose.
03-04-2025 03:57 PM
You will be using the radio coverage of the Chinese networks, but your data traffic will normally be routed through EE's UK central network.
03-04-2025 07:58 PM
Thanks everyone
17-06-2025 10:54 AM
Hi - can I ask did it work? I am travelling next week w work and would like to be able to access Whats app, instagram, netflix and spotify
28-08-2025 01:12 PM
Not true, last time I was there everything was blocked without a VPN - Whatsapp, google, instagram etc.
07-09-2026 04:19 AM
Yes this worked perfectly when on 5G but not on the local wifi, had no issues at all.
