EE Shop said they setup Roaming on our phones for us
KeithDA999
EE shop said they setup Roaming on our phones for US trip. Evidence in text messages that they interacted with 150 to do this but no evidence on EE accounts that Roaming setup and when arrived in US and phones switched on it mentioned costs for calls etc. but no mention that we had purchased EE Roaming. Advisor in shop said the Roaming was £25 each for us and it would enable us to use our existing calls and data whilst in US and to send BACK HOME TO 150 when we return to switch it off. Is this correct that we can’t see reference to this roaming service on our accounts and when switched phones on in US it didn’t mention?
Yes, that would indicate that he set up the free roaming ability for you. He then went on to add the separate independent £25 pm Roam Abroad Pass. The fact that you received a Welcome msg on arrival confirms that your ability to roam is activated.
You should now be able to roam free in the US within your UK allowances.
What is this evidence? Can you post screenshots?
You have got confused between the ability to roam (which is free of charge) and a billing add-on to reduce the cost of roaming - you're not the first and won't be the last.
Thank you for your response.
We had an arranged appointment in the EE Shop to setup Roaming for us. The guy in the shop sent Roaming to 150 followed by Going. He then said that was all setup and would be £25 each to allow us to use our package. It used to be much easier to setup and contact EE.
Thank you
