Abroad with no support
Raygc
I have roaming enabled on my account… I am in the USA, but I cannot send or receive text messages or calls.
I have tried calling the ‘abroad’ support number. It won’t connect. I cannot text 150.
I downloaded the app and have started MULTIPLE conversations, I am told I need to wait for hours to connect to an agent, it times out or disconnects me.
Due to this issue I have lost money, cannot access accounts that need text confirmation and have been unable to respond to a complaint I made, which apparently is now closed as a result.
I have spent HOURS on this and I just need someone to resolve this issue.
@Katie_B
@James_B
@NickBS
@JordanTA
9 REPLIES 9
Northerner
Hi @Raygc
Use Skype over wifi and the number in my signature.
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. Your symptoms are entirely consistent with roaming not being enabled - so what is your basis for saying otherwise?
I have roaming enabled. It confirms that when I call the number via Skype.
Although I am now in a 45 minute call waiting queue.
HOURS and HOURS of time now wasted! 😂
@Raygc wrote:
I have roaming enabled. It confirms that when I call the number via Skype.😂
If so, the problem must lie elsewhere. Roaming allows your phone to connect to foreign networks and thus creates the ability to send/receive texts, make/receive calls and use mobile data.
If necessary, try manually cycling through each available network in turn using your phone's network selection menu.
Northerner
Hi @Raygc
Have you checked your spend cap?
How do you think you have you enabled roaming on your a/c. Was it the overall ability to roam or did you just buy a billing add-on to help pay for any charges while roaming?
I have roaming, because when I got to that on the phone menu (when calling with Skype), it tells me that roaming is enabled. I can use data just fine - just no calls and texts.
This is also part of my package / contract (I am not PAYG).
I don’t have a spend cap which would inhibit this.
I have rebooted the phone multiple times. Issue is not resolved.
Scrolled through all networks - rebooting phone every time - no joy.
Got to what on your phone menu? Your phone settings have nowt to do with your ability to roam on your a/c. All you are seeing is that is that the data roaming setting is ON. That is immaterial.
When you refer to the "phone menu", do you mean one of the on-screen settings menus?
Or do you mean the audible- IVR that's played when you call CS?
