Does this mean roaming is on?
Mummytofive
ee_user14
Skilled Contributor
Skilled Contributor
@XRaySpeX wrote:
@Mummytofive : Not quite! You are covered for using your UK allowances in the EU but you need to make sure roaming is enabled on your account by texting ROAMING to 150 before leaving UK.
Is the wrong answer. The text message shown above IS the response you get from texting ROAMING before leaving the UK, and following the prompts.
The clue is the first sentence "you're all set to roam in Greece" - means roaming is enabled.
ee_user14
Skilled Contributor
Skilled Contributor
So long as the person has enabled roaming on her account, then yes, she is all set up.
