Doctor in Australia. How to ring it won’t connect
Ja1441
How can I ring a GP in Oz? A voice tells me to enter a number to connect but I keep getting static
10 REPLIES 10
Are you in the UK or Australia?
Can you call other Australian numbers?
I’m in Australia. I’m paying for extra from EE while I’m out here. I turned on data roaming and everything else I could think of but I couldn’t even ring my son.
My DIL WhatsApped me, asking if I’d managed to get an appointment, when u told her how ill I felt she made me an appointment luckily. I can’t tell you how scary it was not being able to get help when I needed it.
I still can’t make a phone call for some reason. I’d love to know how to. I have an iPhone 11.
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. Data roaming simply means using mobile data whilst roaming.
Ja1441
I always activate data roaming for when we arrive, we were with EE last year as well and before that O2.
We did get messages off EE both years but we didn’t get one off Optus which we might have had previous years. I have phoned my son previous years but maybe not last year. We FaceTime or WhatsApp family in the U.K.
i think it’s the message off a provider that need to be able to ring people here over the next few months.
Ja1441
Yes we’re on pay monthly.
Data roaming is just a phone setting allowing the use of mobile data whilst already roaming.
You still need to roam in the first place to text-roam or voice-roam. I otherwise refer to my previous post - you've not answered some of the relevant points. Crucially, did you enable roaming prior to leaving the UK, or have you used your phone abroad previously?
FYI you can also edit posts for a short time, negating the need to send multiple short responses.
Yes to both questions. I’m sorry I feel so ill I’m giving up trying to fix this problem.
Thanks for your replies.
Leanne_T
I am very sorry you are poorly and hope you feel better soon @Ja1441
If you could get in touch with our mobile guides once you feel up to it, and would like the account looked into.
The team will check everything from our side for you and make sure roaming is fully set up for you so you can use the phone when you need to.
Take care and please come back and let us know how everything goes.
Data roaming plays no part in making a phone call to a GP. It does not give you the permission to roam.
