Do I have data in morocco
Shona867
If you are on contract, you may use your usual UK allowances outside the EU with up to 500 MB data per day, when you buy the Zone 3 Pass for £7.50 / day. Otherwise you will need to pay the charges or buy roaming add-ons as set out in https://ee.co.uk/help/mobile/roaming/roaming-costs/countries/morocco.
If you are on contract, just remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
If you are on PAYG, just make sure you had already used your PAYG SIM to make a call or text in the UK.
You've put "do I have data in Morocco" as the subject of your post, but nothing in the message itself.
What's your question about using mobile data in Morocco? Are you there now, or travelling there? Do you have a problem using your phone in Morocco?
@Shona867  Only if you purchase a billing add on  you can not use your tariff allowance while there.
