Data and calls in turkey
11Rr
Hi I’m in turkey I have no data no calls no txted received or outgoing
@11Rr : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
