DTMF / touch tones do not work when roaming in the US
chrishammond
Hey everyone,
I have a very strange, but entirely repeatable, problem when roaming with my EE plan in the US. I use a Google Pixel 7 Pro, but I remember experiencing this with a Pixel 6 Pro too back when I had that device.
Whenever I am Stateside, any calls that require touch tone / DTMF dialling to navigate an IVR (e.g., "for another twenty options you didn't ask for, press 1") do not work. I am currently roaming on AT&T, and it does not seem to make a difference whether I am on 4G or 5G. Sometimes my phone will drift over to T-Mobile (US), but this is usually only for a short while so I haven't had the chance to test this network yet.
Not only have I observed this, but I can actually reliably reproduce it using Twilio. I have a trial account with them, so any time I get a call I'll receive the warning message that I'm on a trial account, followed by a prompt to "press any key to run [my] code". No matter how many times I press any key (or which key I press), Twilio will time out and terminate the call. Calling my Skype number, on the other hand, will work just fine and I'll be able to run my code by pressing a key that way.
I have also observed this with Google's hardware support team. When you request a callback, you have to press a key to speak to a human; otherwise, you just get cut off. Again, no matter how many times I tried to do this, it wouldn't work and I had to use an alternative phone that is not roaming in the US.
It should go without saying, but I have no issues at all with DTMF / touch tone dialling when I am in the UK and no longer roaming, so there is definitely an issue here.
Any ideas on how to fix this? I saw in another post that some phones have the option for a longer tone, but I do not see that option on my Pixel. Also, I found a thread on Apple's forums in which an iOS user had the same problem, so this seems to be a network issue rather than a handset one.
Thanks in advance!
22 REPLIES 22
Leanne_T
Hi there @chrishammond
Thanks for coming here.
Do you happen to know anyone else who is on EE and roaming, who is experiencing the same issue?
If not, I would suggest getting in touch with our tech gurus, they will be able to get this looked into for you.
You can find ways to contact us on our get in touch page here.
Thanks.
I'm still experiencing this issue unfortunately! I can't even call 150 because I can't "press one".
Any chance anybody has a fix for this?
Thanks in advance!
Michael_D
Hi @chrishammond.
Have you tried to manually connect to one of the other networks, such as T-Mobile, to see if that lets you call?
If you find that you are still seeing the same thing, you can get in touch with our tech guides by calling 08000798586 through Skype.
Michael
Unfortunately I sometimes can't make calls at all on T-Mobile, depending on where I am, though my phone prefers it. If I have good AT&T signal I can get 5G and VoLTE, but I still can't use DTMF. Verizon is the least reliable for roaming.
Tony_Jef
I have a similar problem but not when roaming. I need to use the "*" key to retrieve messages from my landline answering machine, but when I call the landline using my EE SIM the "*" key doesn't interrupt the answering machine's outgoing message and I can't retrieve messages. If I use my Giffgaff SIM in the same (dual SIM) phone, no problem at all. I've tried with WiFi calling enabled and disabled, the same problem persists. Curiously, when I call a service that requires "press 1 for..." etc. the EE SIM works ok.
Any clues out there?
TIA, Tony
Leanne_T
Hi there @Tony_Jef
I would suggest getting in touch with our tech guides and they will get this investigated for you and let you know what is needed to get this resolved.
Leanne 🙂
Tony_Jef
Hi @Leanne_T  - thanks for your response. I had a look at the page you suggested and not clear to me what you mean by getting in touch with tech guides - do you mean calling 150? No reference to tech guides that I could find...
Tony
Alex_H
Hi @Tony_Jef,
Yes if you call us on 150 or one of the other contact numbers listed on that link, one of the options when you call will be for technical support. If you select that option that should get you in touch with our technical team to run some diagnostics for the issue.
Alex
Tony_Jef
Hi @Alex_H
Many thanks - have just spent a long time on the phone with your tech guys, and they are a little mystified, but are suggesting things to try.
Tony.
