Contacting EE technical help from abroad
Mrswatto
In Currently in Egypt and husbands iPhone 15 has stopped working.
its connected to local wi-fi as are all the devices, but he can’t make/receive calls texts or use what’s app.
we have tried the usual - turn in off airplane mode etc but nothing works.
trying to speak to tech support but none of the numbers are working
any and all advice greatly appreciated
When you say "has stopped working" - does this mean your husband's phone has worked abroad before? I'll assume your symptoms are "I can't use my phone abroad" and you don't have a local network connection...
The number provided isn’t working - keeps asking me to press 1 or 2 - when I press 1 she just repeats the message.
phone was working last night but now refuses to let us look at anything
If pressing option 1 isn't working, press option 2 instead. That said, now knowing your husband's phone was working last night renders the previous advice irrelevant - you've now proven that roaming is enabled by virtue of prior use.
Try manually connecting to alternative local networks in turn - there may be a problem with the specific operator your husband's phone is currently using.
