Cant add roaming data in USA
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-04-2025 12:52 AM
I cannot seem to be able to successfully use the app to change my account to be allowed to add data so I can add data for roaming in USA. When using the text message link to buy the data add on, I'm told I don't have permission to buy data. Yet when in the app or website and try to change my data add on permission, I get an error message and I cannot contact anyone as it's out of hours in the UK. Am I missing something? Or are the app and website down? Texting to 150 is also not working
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-04-2025 01:41 PM
To expand on Rach_H's point.... Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-04-2025 08:24 AM
Hi @Ellida1,
Welcome to the Community!
It sounds like your phone might not be set up for Roaming. Did you call our team before your trip to check this was enabled?
Rach
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
06-04-2025 01:41 PM
- Australian calls in Roaming
- My EE Service not coming back online from beung suspended in Mobile Services
- Roaming not switched on account in Roaming
- Unable to play certain apps/games without a VPN in Mobile Data
- Roaming in USA I am already in USA and need to activate my phone to make calls in Roaming
