on 03-02-2025 10:31 AM
Currently in Germany and can’t make calls to anywhere. Can’t even call EE to sort the issue.
I have an iPhone 14 Pro.
03-02-2025 11:13 AM - edited 03-02-2025 11:13 AM
Can you send texts or use data?
