14-02-2025 03:38 PM - last edited on 15-02-2025 09:56 AM by Michael_D
Yes, we have the same problem. Currently roaming on Swisscom. We get the number unobtainable noise and a message in German saying that 'this number cannot receive calls'. We have it on 2 different EE sims. Both have always worked in the past.
[Mod edit - added subject title as it was removed]
14-02-2025 04:28 PM
Hi there @445Forest
Thanks for coming here and letting us know.
Do you get the same message making and receiving calls? Can you send texts?
Have you tried to manually select a different network to see if the same happens?
Speak to you soon 🙂
15-02-2025 08:40 AM
Thanks @445Forest
Can you try to make the calls using 0044 instead of +44.
Also, if you are using an iPhone, can you try to turn off Dial Assist by going to Settings then Phone, then turn Dial Assist off?
Let me know how that goes.
Michael
15-02-2025
09:51 AM
- last edited on
15-02-2025
10:37 AM
DanielPA
+44 is an international standard, manually changing networks to rule out a local issue would be the first test.
