Bosnia hardwork…
Twhelan90
I’ve just landed in Bosnia!
My texts to 150 wont go through! All i want is some data, why is it so much hard work?!
it was never this much hard work when i was with o2!
currently sitting in my hotel room scared to leave as i dont want to get lost! Can someone help?!
Northerner
Hi @Twhelan90
Are you PAYG or pay monthly contract.
You can contact EE via Skype and the number in my signature.
