All rounder roaming in USA
Sharonc85
Hi there
I am confused with the all rounder roaming, will i be able to use my UK minutes, texts and data in Florida with no charge?
I go away in June and i would like to get this clarified before i go away
Peter_W
Hey @Sharonc85 😊
Welcome to the Community!
Our current All Rounder plans only offer EU roaming as standard, so coverage in the USA wouldn't be included by default.
Also whilst this isn't an option now, some older versions of All Rounder did let you pick this add-on as your swappable inclusive extra.
If you send a text with PICK to 150, it will let you know if this is one of the options that's available to you.
Otherwise it would just be a case of purchasing a pass once you arrive, and you can find all the details you need on these options here:
Roaming Costs | Help | EE
Peter
