on 16-12-2024 12:02 PM
Hello, I already paid £10 for EU roaming in Italy but I still cannot use it. Can you please help me to check?
on 16-12-2024 12:21 PM
on 16-12-2024 12:24 PM
I am using EE for a few months and £15 top up every month. But i am travelling in Italy now, after I sent ROAMEU7D to 150, I cannot use the roaming daya
on 16-12-2024 12:39 PM
Hey there @Tannahui, welcome to the Community!
When you arrived in Italy did you get the welcome message confirming you have connected to a local network, or have you had no service full stop since arriving?
Also have you ever made a chargeable call or text in the time you've had this number, or have you always just used the pack allowances?
Peter
