plan
jcb_010
ive just bought £15 and i wanted the PLAN15 but its not working i always have this issue i end up going to the store but cant go right now so need help pls 🙂
Lesley_W
Hi @jcb_010
I'm sorry you have had trouble activating your plan, have you been able to get this sorted?
It may be worth a call to our customer care team on 150 if this is happening often.
Lesley
Northerner
Hi @jcb_010
Try restarting your device.
What does it say if you text BA to 150.
it says:
Your current balance as of today 05:57 is £15.17. Your last top up was £15.00 on 04/10/2025 at 00:36. For more info on your plans, add-ons or free boosts, go to the EE app or ee.co.uk
Northerner
Hi @jcb_010
If you have restarted have you tried adding the Plan15 again?
yes i did try a lot of times it keeps saying:
To buy your £15 plan again, simply top up £15 and your plan will start automatically.
Lesley_W
Hi @jcb_010
Lesley
