on 25-05-2026 12:18 PM
I was purchasing a PAYG plan and I pressed the 22gb £10 flex plan but when I brought it I ended up with the 2gb one. I don't know if my finger slipped and I pressed the wrong one after but I can't afford to purchase another plan at the moment. Is there any way that I can fix this?
Solved! Go to Solution.
on 25-05-2026 04:06 PM
Hi @bill117,
Welcome to the Community!
If you reach out to our team then they will be able to take a look into if we are able to switch you to a different pack to the one you currently have active.
Rach
on 25-05-2026 03:35 PM
What does texting AL to 150 from your no. fully report verbatim (it is free)?
Hi @bill117,
Rach
