Top up using a voucher
Zee14
Hi
i was wondering if you can still use a voucher to top up as it only says you Top up online using a credit card
nick_ro
Valued Contributor
Valued Contributor
Yes you dial 150 and go to the top up option. After hours it will tell you to press 1 for automated services. I think 360 takes you straight to the top up service.
Make sure your sim is active if you haven't used your EE sim for a long time.
Also make sure you top up an amount enough to cover your pay as you go pack.
17 REPLIES 17
@Zee14  Yes you can.
nick_ro
Valued Contributor
Valued Contributor
I need to top up from outside the UK, have a voucher but am a bit lost on how. Do I still try to call 360? Or ±44360
Leanne_T
Morning @Lonewolf_au
Where are you at the moment?
Can you try the below options for topping up with a voucher:
Text 150 with VO then a space and then the 16-digit voucher number
e.g VO 1234567891234567
Or, call 150 from your EE phone and follow the instructions
Also outside the UK
Can't top up with voucher. What else can I do?
Christopher_G
Whereabouts are you, @King22?
Have you tried both the text options and calling 150/360?
Won't work in Africa.
Christopher_G
Which country in Africa are you, @King22?
MarcDiocares
I already have voucher for the Ee using recharge app
