Phone was reconnected. I topped up and not working.
blueblue48
My phone was disconnected but then EE reconnected the phone.  I have since topped up, the email confirmation advised I could use straight away but I am unable to do so.  Do I need to wait 24 hours or something?
8 REPLIES 8
James_B
EE Community Manager
Hi @blueblue48,
Yes, please allow up to 24 hours for your SIM to be reconnected.
blueblue48
One more question.  This is a pay as you go phone, but I have been advised it needs to be registered. My understanding is that this is not necessary.  Please advise. It's been 24 hours and the phone still does not work and I have topped up with £30!
James_B
Was your account in hibernation due to not being used for a while @blueblue48, or have you made an account change - such as moving to pay as you go from pay monthly?
Thanks James:  It's not used a lot but every month, I'll send a text just to keep it active.  No change to the account, it's always been pay as you go.
James_B
Why was your phone/SIM disconnected @blueblue48?
blueblue48
No idea.  There was ample credit on it. Like I said, it was 'used' on a monthly basis just to keep it active.   Just tried to send another text and it's stuck in the outbox.
James_B
Hi @blueblue48,
Your account wold only enter hibernation if there was no chargeable usage for 179 days or more.
As we're unable to determine the reason your account was suspended, I'd recommend contacting Customer Care who can access your account and get to the bottom of it for you.
They'll be happy to help. 🙂
Sending a text from your pack is not enough to keep it alive. It needs to be a chargeable action.
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
You don't need to register a PAYG no. in order to use it.
