12-02-2026 11:23 AM
Hi, not sure if this is the right place for this but I use a PAYG SIM card with a monthly plan - unlimited calls & texts and either 20 or 25gb of data which rolls over to next month if I top up within seven days - it had ran out so like usual I topped it up and the money stayed in credit for hours when it usually takes the money straight away to renew the monthly plan but this time as it never took the money straight away I went onto my myEE app and it said there was no monthly plan in place which meant I had to then purchase a new monthly plan which meant I lost over 40gb of data.
Has this happened to anyone else? Anyone know why this happened?
12-02-2026 02:15 PM
Hi @jb-1994 👋
Welcome to the EE Community!
Usually pay as you go plan will auto-renew, but you can also select this kick in manually by sending a text with NOW to 150.
Sometimes if you're on an older plan you'll be required to move to a new one, but provided you're staying on a 30 day option you shouldn't lose any existing free boosts.
So we can be sure on what exactly has happened here, I would recommend getting in touch with our team so they can check your account, and make sure everything is as it should be.
Peter
12-02-2026 02:15 PM
Hi @jb-1994 👋
Peter
13-02-2026 11:33 AM
13-02-2026 12:12 PM
Cheers @jb-1994.
It does seem an odd one, but fingers crossed our team will be able to shed some light on what exactly has happened here, so it's definitely worth giving them a call.
Peter
13-02-2026 03:20 PM
@jb-1994 wrote:I had to then purchase a new monthly plan which meant I lost over 40gb of data.
You don't lose you rollover data as long as you buy your new pack within 7 days of the previous expiring. It doesn't matter if the new pack is auto renewed or bought manually.
Texting NOW will never work when you have no pack already to start now.
21-09-2026 07:03 PM
The same thing happened to me this month. I have had the same 30day PAYG top up plan since I bought the phone in 2021 - 5GB data 100minutes and limitless texts but suddenly this month did not top up and I had an account credit. I tried the Contact Us links and there are just automated responses. I tried a few times and it went round and round with no response to my question. I had about 20GB rolled over which appears to have vanished. A courtesy would have been to let me know if there were going to be changes but there was no message or note on my account.
22-09-2026 08:06 AM
Hi @Wombl
As long as you buy a new pack within 7 days of the old one expiring your rollover should remain.
However, I'd recommend getting in touch with customer service where a guide can check your account and what had happened.
Ali
