Number Deactivated After Inactivity
vannyrao19
Hi everyone,
I'm hoping someone might be able to shed some light on my situation. I have an EE SIM card that I purchased in the UK and used for a year while living there. I returned outside UK last September and haven't recharged the SIM since then.
For a while, I was still able to receive OTPs on the number, but that stopped in March. I'm now concerned that my number might have been deactivated due to inactivity. In fact, I see a message of 'Closing Adjustment' on 26 March, after which I stopped getting messages.
Has anyone experienced something similar? Is there any way to reactivate my number. I haven't been able to find a chat option or email address to contact customer service directly. Only call is available which I am not able to do from here as I am out of UK.
Also, if I purchase a data pack now, would that reverse the deactivation?
Any advice or suggestions would be greatly appreciated!
Thanks in advance.
1 ACCEPTED SOLUTION
Got it solved. Called this number 00 44 7953 966150 and they removed my number from hibernation. I am outside UK so used this number. Just one phone call and it was solved.
Thank you for the reply.
9 REPLIES 9
@vannyrao19 : Sounds like your PAYG SIM has gone into hibernation & then completely deactivated.
When did you previously make a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
I topped up right now with £10 right now but nothing happened.
It's too late now! It's already gone into hibernation & worse.
Halidekerem02
İ am living the same problem
İ cant call i am outside uk
İ am out of uk
@Halidekerem02 wrote:
İ am living the same problem. İ cant call i am outside uk
If your problem is the same, I would suggest following the advice - it will also be the same. The post from 12/05 @ 5.42pm includes reference to calling from outside the UK, including the international contact number.
