on 28-03-2025 10:34 AM - last edited on 28-03-2025 10:49 AM by Leanne_T
hello, ******** was my number, I registered in my name with EE support, now it got disappeared and my sim no longer works in my phone, I live outside of the uk, is there a way or a solution that brings me same number back?
[mod edit: removed personal details from the forum]
Solved! Go to Solution.
on 28-03-2025 08:52 PM
Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
28-03-2025 12:38 PM - edited 28-03-2025 12:39 PM
Hello @darw901 ,
Welcome to the community,
Did you first activate and use the SIM card in the UK. If pay as you go, did you make a chargeable call or text in the UK?
Sim cards have to first be used in the UK for them to work abroad.
If on contract, did you activate roaming in order to use abroad? Not necessary for pay as you go, as they are automatically enabled.
on 28-03-2025 12:42 PM
on 28-03-2025 04:17 PM
on 28-03-2025 04:29 PM
on 28-03-2025 04:34 PM
Do you know roughly @darw901.
If you do not use your SIM for any chargeable activity for 179 days then your account will go into hibernation, and you would need to speak with our team to end the hibernation.
After 269 days then your SIM would be cancelled, so this may be what has happened. We do send you text messages to let you know this will be happening, but if you've not been using your SIM then you may not have seen this.
Rach
on 28-03-2025 05:54 PM
28-03-2025 06:06 PM - edited 28-03-2025 06:06 PM
It sounds like your number is either in hibernation, or has been cancelled @darw901, and you would need to speak with our team to confirm if we are able to reactivate this for you.
Rach
on 28-03-2025 06:12 PM
