09-09-2025 12:15 AM
Can someone PLEASE tell me how I can change to a lower plan ? Because since EE have “automatically” changed my plan to double the amount I was originally paying, no matter what I try, both via the App and the Website, I ONLY get shown the “plans” on how to UPGRADE and not on how to “change” to a more affordable plan, i.e; to “downgrade” my plan. Thank you 🙏🏻
09-09-2025 09:31 AM
Great advice from @XRaySpeX, If you're currently on a pay as you go account, I'd recommend following that advice.
You mentioned only giving you the plan options to 'upgrade' so if you're currently on a pay monthly plan, I'd advise giving us a call so a guide can look into some options for you.
Chris S
09-09-2025 01:12 AM
Text ALL PLANS to 150 & select one to your liking.
09-09-2025 09:31 AM
Chris S
09-09-2025 09:39 AM
@Chris_S : I'm sure when I replied this thread was in the PAYG forum or I'm all mixed up. Now it's under Contracts ...
@Anthony-Wayne : You can't downgrade to a cheaper plan mid-term, but only in your upgrade window from 30 days before end of term.
