Content lock
Sirmarveloumarv
I will be getting mine turned off but it looked like my ee shop was closed so didnt get done so shall call to get removed during the up coming week .but for the people  who cant be asked to go to there shop or use there card there a way to go on 18 plus sites use a free vpn app and then you can
Sirmarveloumarv
You cant you either take I'd and go to shop or use card over fone .but you can go around it if you got a free vpn app activate it then you should be able to look at what you want worked for me.
Sirmarveloumarv
Or you can dload a free vpn app activate it then you should be able to use your phone.but just as easy to take I'd and go to shop.
On PAYG you can't control Content Lock from your MyEE. Instead you need to call EE with a credit card handy & pay a refundable token amount to prove you are over 18. Alternatively you can visit an EE store with some photo ID.
