01-11-2026 09:35 AM
Hello, I purchased a poly voyager 4320 headset Aug 2025 and this has gone faulty as people cannot hear me.
can someone please advise where I go with this.
01-11-2026 10:28 AM
Hi @Stevemc34
It would be the Consumer Rights act and you'll need to prove the fault is one from purchase after all this time.
As @Chris_B says I would suggest contacting the manufacturer and claiming under the warranty if still valid. I would however check the HP community forums as as this maybe another issue or solution available.
01-11-2026 09:55 AM
@Stevemc34 As it’s over 12 months I would check the included paperwork that came with the headset to see what warranty it has. This is the manufacturer warranty.
01-11-2026 10:00 AM
I’m not sure I have this still. However this would also be covered u see sales of good ls act as currently it isn’t fit for purpose
01-11-2026 10:28 AM
Hi @Stevemc34
