How to text 150 From data only tablet
Alecc1
Schockwave
Hello @Alecc1 ,
Welcome to the community,
What tablet are you using? If it is Apple and you have an Apple phone, you should just click on new message and then put in 150, I suspect it would be the same with any other make or model.
grsdev
Expert Contributor
Expert Contributor
As far as I know, a "data only" SIM allows you to place/receive calls and send/receive text messages the same as a "phone" SIM. Depending on the plan you have for the tablet, you just get billed for it.
@Alecc1   What tablet is it ?
It's an Amazon fire 10 pal
Leanne_T
Hi @Alecc1
Are you able to put the SIM card into a phone to send the text?
What information would you like from the text message?
Thanks 🙂
