How do I unlock a 4GEE mini without an EE sim card?
grlebo
I have a 4GEE mini router, but I don't have the EE sim card that came with it.  I am in the US, so I cannot get to an EE store.  I would like to unlock the router so I can use another SIM card in it (in Chile).  Is it possible to unlock the router without the EE sim card?  I cannot text EE to get an unlock code.
Thanks for your help!
7 REPLIES 7
@grlebo : You don't use an EE SIM to unlock an EE device away from EE. You need another network's SIM, but I can't swear a foreign 1 will do, & its unlocking code.
You can just apply for unlocking by using the Unlocking your device form and giving its IMEI no., which you can obtain be dialling *#06# into its keypad.
OK, thanks for the direction. But, I have tried that a couple of times since your reply and have received the message:
"Please try that again
Sorry, something went wrong on our end. Please enter your IMEI again or come back later"
Is there something more that I should do?
Thanks!
Leanne_T
Hi @grlebo
Thanks for coming back to us.
If the online form is not working for you, please call us on +44 7953966250 and the team will be happy to help.
Leanne 🙂
I have rge same issue.
I have an iPad mini locked to E.  The online tool does not work as it keeps saying"
Sorry, something went wrong on our end. Please enter your IMEI again or come back later".
The cutomer services number in you Post takes me to a menu  which I cannot dial with the iPad and when I use an iPhone (anothernetwork) it tells me not an EE device.  The link obtained by texting 60071 takes me back to
Sorry, something went wrong on our end. Please enter your IMEI again or come back later".. Come back later - it's two days of tryimg now.
There are 5 menu options for that EE number - which one do I need?  Option 5 -for unlocking does not get me anywhere.  Thank you
Leanne_T
Hi @drrbr1
Please call us on 0800 956 6000 and select option 1, the team will help you with unlocking the device.
Hello
Thank you.  I did that (different number) and EE resolved the issue.  Took 43 minutes plus 25 minute wait time though.  Apparently specific procedure for Mini 1st generation.
Leanne_T
Thanks for coming back and letting me know @drrbr1
Leanne 🙂
