ongoing order
sophielou_991
i placed an upgrade order on the 12th november, i had an email saying my order has been confirmed, but since then I have not been able to track my order. Is there there anything you can do help? its an iphone 14 pro deep purple
1 ACCEPTED SOLUTION
Christopher_G
Lovely, thanks for confirming, @sophielou_991.
The current estimated delivery timescale is to expect dispatch within 14 days. DPD will send you a message when it's ready to be delivered.
Thanks for your patience so far.
Christopher_G
Hi @sophielou_991
Welcome to the community.
I'll check our estimated delivery times for you. Is it definitely the iPhone 14 Pro and not the iPhone 14 Pro Max? Which memory size did you choose?
Hello yes I'm sure it's the
iPhone 14 Pro
128GB Deep Purple
Christopher_G
