iPhone 14plus query
SN34
On the page that gives the details of my upgrades its has an offer for iphone 14 plus, this says its £38.17 instead of £50.17 but when I select the costs that equal to £50.17 it doesn't change to the offer price. It says 'upto £288 off with trade-in' however this amount doesn't corralate to that reduction.
I darent select it and see if it goes through at the end in case it doesn't and then I'm lumbered with the higher cost for a few years.
Has anyone bought a mobile where it had this sort of price reduction on the first page and how did this reduction go through?
Any help would b eappreciated.
1 ACCEPTED SOLUTION
Katie_J
Hello @SN34
Welcome to the community.
When you are at check out does any discounts show in the break down?
What is the plan you are selecting?
Katie
Katie_J
Hello @SN34
Katie
