27-05-2024 02:56 PM
Just done a mobile phone upgrade and I was offered a samsung watch which i actually want, but when going to order it i was then asked if i wanted to keep my number which i said yes, then i was asked for a "pac" number and when i got the pac number the text said that pac numbers are used for leaving the service. Just looking for some advice if anyone has recently done this. I would like to keep my number and have the watch in addition to my current plan.
28-05-2024 08:04 AM
Morning @DaveRussell93
Thanks for coming to the community 🙂
You won't need to select keep your number, this option is for transferring numbers from another network.
Once the watch has been received you would set this up to connect to your existing mobile number 🙂
