Re: Order tracking
Kirsty345
Can you help me please , I have 2 order numbers do the same order but neither are working on the tracking link. Therefore cannot track. I don’t have any updates on my order apart from the confirmation that EE has received it. Thank you.
Debbie_G
Hi @Kirsty345
I'm sorry you've been unable to track your order. If you’ve received more than one order number, I’d recommend getting in touch with our customer support team. They will be able to check the status of your order, get you an update, and confirm the correct information.
Debbie
Debbie_G
Hi @Kirsty345
Debbie
