Problem receiving order
Danieljsilva
I upgraded online to an iPhone 15 Pro Max.
Everything went well until then, the DPD delivery man came to make the delivery and asked for a PIN that would be sent in the SMS, but the registered number is different from my number and I didn't receive it. Is there a way to change this number? Or just receive the order at home with ID or some other alternative, because the delivery person will return again tomorrow.
Leanne_T
Hi @Danieljsilva
Thanks for coming here.
Is the other number that the PIN has been sent to also on your EE account?
17 REPLIES 17
@Danieljsilva  if you download the DPD app and create an account with the same email address that used for EE. You’ll also see this four digit pin on there.
I did this but it's not there, just old deliveries.
Leanne_T
Hi @Danieljsilva
Hi @Leanne_T , Yes, it's on a number I used a long time ago, and that account has now been closed.
Leanne_T
Thanks @Danieljsilva
Could you try logging into the DPD app using the mobile number that the PIN has been sent to and the postcode, does this work for you?
@Leanne_T I tried this but to register the number with DPD they ask for a code that will be sent in the SMS, but as this number is deactivated I didn't receive anything. One option would be to reactivate this account but I don't know if that's possible, it's listed as a closed account.
Leanne_T
I see, thanks for trying @Danieljsilva
In this case, please call us on 150 and our mobile guides will get this looked into for you.
Leanne 🙂
@Leanne_T I tried calling 150 using the old number, but it's not possible, probably because it's deactivated.
Leanne_T
Hi @Danieljsilva
Do you have another EE phone to call from?
If not, you can call us on 0800 956 6000.
