Pin for delivery
Lollypop851
OK so I'm expecting delivery of my phone today but  not had any communication from ee regarding the pin I need to give to the driver when or where will I get this
8 REPLIES 8
Alex_M
Star Contributor
Star Contributor
Hi @Lollypop851
Did you receive a text or emailfrom DPD today?
If you need to give the driver a pin for delivery then it would have been on the text/email.
If not then no pin is required, just photo ID.
Thanks,
Alex
 If I solved your issue, please click the solution button below!
 If you found my post useful, click the thumbs up button!
 To speak to EE, call 150 from your EE mobile or +44 800 079 8586 (freephone) or start a live chat.
Useful Links: My EE | Live Chat | Bills | Usage | Network Coverage Checker | Abroad | APN Settings | PM
No but have the consignment number which I got free ee and dpd tracker says delivery  today
I've had no communication from ee regarding this delivery which I think is terrible and unfortunately I have no photo I'd
Tynuttzza
Hey, I'm having the same problem, no pin, no notification from DPD but they are saying on the dpd tracker that it's out for delivery. How did you get sorted with yours?
James_B
EE Community Manager
Hi @Tynuttzza,
I'd recommend contacting Customer Care so a member of the team can double check the contact number on your order.
They'll be happy to help.
Hey James
Yes, I did, apparently the driver sends the pin before attempting delivery....
There isn't a time frame for that on the tracker, this does not seem like an ideal situation, its disappointing that you don't even get an estimate about when this delivery is meant to take place, its meant to be today but I didn't really get a notification about it... it was meant to be yesterday as well according to the tracker.
Profile closed
Not applicable
@Tynuttzza I had a phone from EE last week and the pin showed in the DPD app.
I worked out that the phone I ordered didn't need a pin it depends on the
value of the phone weather it needs a pin
Karola2929
I'm waiting for pin for today delivery
