Order
graciebabe391
I placed an upgrade order online received the email conformation but not heard any more. Can't get live chat to work. Are you able to help me with this please.
Katie_J
Hi @graciebabe391
If live chat has not yet appeared this is due to agents being busy.
I would recommend giving your local store a call but roaming will need to be activated.
Katie.
43 REPLIES 43
James_B
EE Community Manager
Hi @graciebabe391,
When did you place your order?
Which phone did you choose?
graciebabe391
I put for my phone to go to local EE Store but I'm in Gran Canaria until the 12th. Will the store hold it for me. I can't get into live chat so can't ask them. Any help greatly appreciated. Thank you.
Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
graciebabe391
I am unable to txt or receive txt messages. I'm in Spain. I can't track my order either.
@graciebabe391 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise try logging into your MyEE account online & go to Menu > Account Settings > Parental and Data Controls > Roaming Abroad and also Call Abroad and Premium Rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. over Skype. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything.
Did you try calling over Skype over WiFi as I suggested?
graciebabe391
I don't know how to do that. Thank you anyway.
Can't you install Skype on your device & connect to a WiFi hotspot?
Katie_J
Hello @graciebabe391
Do you have Roaming active?
Are you trying to access live chat by using your My EE app?
Katie 🙂
